Revit MEP
Member
chikewei78
Message 1 of 5 (414 Views)
Can't cut section in the floor of new Revit Model
414 Views, 4 Replies
12-12-2013 11:39 PM
I built a new MEP Model.   I have linked the MEP template, Archi model and Structural model.   Then I start to build the Fan.
The question is that I can't cut the section on the floor plan.
The warning is as follows.
how can I do?
Active Contributor
danielkazado
Message 2 of 5 (395 Views)
Re: Can't cut section in the floor of new Revit Model
12-13-2013 07:33 AM in reply to: chikewei78
Hi, Did you checked the Discipline of the Floor Plan Properties. Changing to Coordination may help. Daniel Kazado
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
*Expert Elite*
abulla
Message 3 of 5 (383 Views)
12-13-2013 09:59 AM in reply to: danielkazado
There are a couple dozen reasons why that message will pop up in Revit. Here are a few of them:
1.Is the correct Workset being used?
2.Is the view range set correctly to see the particular element?
3.Is the object hosted on an incorrect surface like a floor instead of a ceiling?
4.Is there a filter applied to the view that is causing the element to be hidden?
5.Is the detail level of the view set correctly? Some families are set not to show at Coarse.
6.Try using the “Reveal Hidden Elements” tool in the view control bar.
7.Is there a plan region in the view?
8.Is the view “Discipline” set correctly?
9.Is the element in the correct phase and is an appropriate phase filter set in the view to make it visible?
10.Is the element part of a design option and perhaps that isn’t the current option for that particular view?
Active Contributor
harinarayana55
Message 4 of 5 (373 Views)
12-15-2013 12:26 AM in reply to: chikewei78
please check one more hide scales coarser than in section properties.
Member
chikewei78
Message 5 of 5 (366 Views)
12-15-2013 05:56 PM in reply to: chikewei78
Thank you all.
The section has been shown after I select the section box in the Annotation Categories.
Need installation help?
