in 3d view draw pipe horizon axis is easy but
can we manage it up to vertical ?
not setting work plan every dimension which is uncool
maybe there will be key for locking to vertical axis
Solved by bvm76. Go to Solution.
Yes. While on the 3D view and under draw pipe command, enter the desired offset and hit enter/apply once if you still want to continue the pipe command and twice if you want to end the command.
