Revit MEP Forum
can draw pipe in 3d view properly ?
3 REPLIES 3
amg.monaco
3198 Views, 3 Replies
in 3d view draw pipe horizon axis is easy but
can we manage it up to vertical ?
not setting work plan every dimension which is uncool
maybe there will be key for locking to vertical axis
3 REPLIES 3
bvm76
in reply to: amg.monaco
Yes. While on the 3D view and under draw pipe command, enter the desired offset and hit enter/apply once if you still want to continue the pipe command and twice if you want to end the command.
Please mark Accept as Solution if your question is answered!
Thank You.
amg.monaco
in reply to: bvm76
Yes but do you mean offset ?
bvm76
After you drawn your horizontal pipe in 3D say at 2700mm, enter 3500mm in the offset box and hit enter/apply. This will automatically create the vertical pipe.
Thank You.
