Is there any way to route electrical cables through cable trays in order to have a quantitative information not only about the cable lenghts but in order to allow a previous cable reel cut? This is something that we have in plant design systems like PDMS and I supose that REVIT may have something similar.
Joao Laudares
Solved by Samir_emam. Go to Solution.
Solved by CoreyDaun. Go to Solution.
Cable Tray is currently a "dumb model" and does not house or contain any electrical or cabling/wiring information. Revit is far behind when compared to most other programs, especially in the Electrical discipline. It is improving, though, albeit slowly. Below is a link that is frequently provided by Autodesk Support personnel in these forum; use that to submit feedback. Provide details and examples if possible.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you for Corey. I will post some explanations about our needs to the development group.
Joao Laudares
Dear Sir
Kindly check Electrical Power Cable Add-ins from following links:-
And pro product:-
Kindly check my You Tube channel videos which describe "Electric Power Cable Pro" Add-ins options through the following link:-
Electric Power Cables Add-ins videos
I wait your feedback.
Dear Sir
And pro product:-
A really impressive work, Samir. I will share the videos with the people that are in charge of the electrical infrastructure design here on our company. I will come back with the comments.
Best regards,
João Laudares
