Revit MEP
Distinguished Contributor
16 Kudos
Post 1 of 6
cable tray connector
706 Views, 5 Replies
11-18-2013 04:38 AM
i am trying to make a cable tray fitting but i can't figure out why the cable tray connector is not in line with the face of the tray that i selected. the width is fine and the height is the problem. Please see attached.
Please mark Accept as Solution if your question is answered!
Thank You.
It has to do with that the connector is connected to the U-shaped face. It connects to the center of gravity of the face. Solution is to connect it to a workplane or alternatively create a (small) object were you can connect your connector to. This object with connector can than be located/placed in the right spot. In your case I would go for workplane based connector.
Too add to EnlInt's suggestion of creating a dedicated extrusion to host the Connector: you can disable that extrusion's Visibility  and the Connector will still be available. Alternatively, you can create the core extrusion as a solid bar and use a Void Extrusion to carve our the cavity, which will leave the connector centered on the face.
1,007 Kudos
Post 2 of 6
Re: cable tray connector
11-18-2013 06:39 AM in reply to: bvm76
Can you attach the Family file? Also, what version of Revit are you using?
16 Kudos
Post 3 of 6
11-18-2013 07:47 AM in reply to: CADastrophe
please see attached.
i am using revit 2013.
Thank You.
Distinguished Mentor
192 Kudos
Post 4 of 6
11-18-2013 08:16 AM in reply to: bvm76
1,007 Kudos
Post 5 of 6
11-18-2013 08:58 AM in reply to: bvm76
16 Kudos
Post 6 of 6
11-20-2013 09:06 AM in reply to: CADastrophe
I created a solid sweep with the same width and height as the U-face tray and it works. Thanks guys!
Thank You.
