Is there any way to change the colour of cable tray types. E.g. say I have a type for fire alarm that I would want to be red, or a type for power that would be green.
Many thanks
Regards
You can do this with filters.
You can either make a different cable tray type for each service, or add parameter that will allow you to define what service the tray is carrying.
Then you can make a filter (in visibility graphics) and set a colour fill override.
Hi embolisim
If we create Cable tray type for each service, surely to getting the cable tray fitting the same color as the tray, we will need to also create cable tray fitting family for each service also, plus additional filters.
I guess once its created, it only needs to be done once, but is there a better way than this?
Ive also used identity data - service type in the properties panel and created my own types in there, but that isn't a great solution either, as the created systems don't get stored in there and i have to type it in every time.
Guy
