Revit MEP
akaymurat
Message 1 of 9 (990 Views)
Building type and Space Type
990 Views, 8 Replies
12-31-2012 01:39 AM
does revit mep allow to us define a new space type and building type, Except for existings? and how can i create a new type?
Murat AKAY
Mechanical Draftsman
Hvac-Fire-Plumbing-Piping
LisaDrago
Message 2 of 9 (965 Views)
Re: Building type and Space Type
12-31-2012 01:21 PM in reply to: akaymurat
To my understandings - you cannot create new ones. Below is an image of the existing types available.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
akaymurat
Message 3 of 9 (903 Views)
01-04-2013 02:36 AM in reply to: LisaDrago
i checked that your sent image. for instance, if you want to design a medicine factory, how will you add a building type as the medicine factory and space type
Thanks your answers
Best Regards
Murat AKAY
Murat AKAY
LisaDrago
Message 4 of 9 (899 Views)
01-04-2013 05:10 AM in reply to: akaymurat
Maybe I am not fully understanding you.
The building type and space type parameters are used for calculating heating and cooling loads. You can adjust these settings from the default values - but over all this helps to set the parameters for the model and then down to spaces to create accurate analysis for load calculations.
You cannot add to or remoeve the existing spaces.
Not sure if this relaly helped...
LD
New Member
kemalaldemir
Message 5 of 9 (879 Views)
01-05-2013 02:52 AM in reply to: akaymurat
Hi all,
Actually, the main problem is that,
We are trying to define a space or building type, except already defined ones. The main question is, how can i define room conditions instead of existing? For example, i would like to set a room as a pharmaceutical laboratory, which needs very special conditions. Could you please tell how can we adjust and dedicate settings of the room?
Thanks in advance,
New Member
jschaad
Message 6 of 9 (640 Views)
08-26-2013 04:47 PM in reply to: kemalaldemir
Did you ever find a solution to the problem of space types?
My firm is primarily in the design of bio-tec and pharmaceutical manufacturing facilities. As you know none of the Revit “space types” even come close to suiting our needs for space types. If I/we cannot add any space types then the Revit analysis tools are essentially useless to both of us. So now back to my question: Have you found a work around or a way to create additional space types? The only way that I can think of is to use another space type ex. “conference” and change its characteristics to match an “MSI lab/clean room.”
Or, if anyone else has a solution to this problem please reply.
CADastrophe
Message 7 of 9 (617 Views)
08-27-2013 07:59 AM in reply to: jschaad
jschaad wrote:
"...The only way that I can think of is to use another space type ex. “conference” and change its characteristics to match an “MSI lab/clean room.” "
Unfortunately, I believe that is the only solution at this time.
New Member
kemalaldemir
Message 8 of 9 (600 Views)
08-28-2013 01:37 AM in reply to: akaymurat
Unfortunately we couldn't find a proper solution.
akaymurat
Message 9 of 9 (595 Views)
08-28-2013 01:45 AM in reply to: CADastrophe
unfortunately we haven't yet solved :smileysad:
Murat AKAY
