I'm trying to somehow apply a bold, wide dashed line to just one view of a wiremold family I am creating. If I could just draw a model line and apply a thickness and dashed linetype to it then I'd have what I'm looking for but as far as I can tell, that's not possible in Revit.
One solution I tried was creating a custom hatch pattern in AutoCAD and then importing the .pat file to Revit but I wasn't able to create the hatch pattern I need.
The Vertical Poche material pattern would work great also if I was able to apply a thickness to the lines in the pattern but again as far as I can tell I can't do that in Revit.
Does anyone have experience with applying a custom material or a custom pattern in Revit? If so, how would you recommend I create a 2" thick dashed line pattern?
Thanks for any help offered.
