Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Autosave
6 REPLIES 6
312 Views, 6 Replies
Autosave
Does Revit MEP 2009 have something like autosave option like Autocad has - in case of crushing and wanting to restore (to some point) your done work?
6 REPLIES 6
dennis
Not like AutoCAD. The only thing you have is the reminder. So the rule is, save quickly and save often to your local.
Does anybody know what to do in case your computer crash and you need to restore work lost?
dennis
When u save to the local, Revit will rename the 'original' to the same name with .001 in the name. Depending on your settings, you may find up to 5 of these. Example, ABC.RVT saves and then you will have ABC.001.RVT as well as the ABC.RVT. Then as subsequent saves are performed you could have ABC.001,RVT, ABC.002.RVT, ABC.003.RVT and so on. These 00x files are akin to the BAK.
Thanks Dennis. I know about this "back-up" option. It is better than nothing but the "aotosave" question still remains. I hope in the future releases of Revit Autodesk will address this issue.
luisPDAN6
Please have a look at this:
s.borello
Sadly no... only reminders.
