Revit MEP Forum
AutoCAD like Area command
5 REPLIES 5
1325 Views, 5 Replies
Is there an "AutoCAD" like Aera command where you pick points to get a sq.
ft result?
5 REPLIES 5
scritz
Draw a filled region or masking region around the part of the building you need the area for and then select the filled region and click properties and it will display sq ft.
Thanks that works great
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Draw
display sq ft.
Chad-Smith
Has been asked for many times now for many years, but unfortunately still no.
It would be nice to get a quick throw away area (you know, like the Tape Measure does), without the hassle of creating a Filled Region.
simon.whitbread
Why not use the 'Area Plan' Tools?
Create a set of Area Plans
Add Areas
Keep
Done
Chad-Smith
Not all views are in Plan. How about for Sections and Elevations?
Not everything you do in Revit has to be permanent. Why not do away with the Tape Measure tool and use Dimensions when-ever you need a distance? It's not all that convenient is it. Edited by: cgsmith on Jun 15, 2009 9:02 AM
