Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Auto increment
1 REPLY 1
alatier
863 Views, 1 Reply
Auto increment
Is there a way to auto increment a tag in the same way you can in Autocad with lisp using the user1 to user4 variables to store the last value with the file?
I want to tag elements (assemblies) in a file, but the pipe marks automatically generated by revit doesnt work for me (i need to combine 2 or more pipe segments under 1 tag
It would be then even better if these tags could be extracted, sorted and counted as you can in autocad with eatte
Pete
1 REPLY 1
CoreyDaun
in reply to: alatier
You should take this question to the Revit API board, as this cannot be accomplished with Revit's baseline functionality. There very well may even be an Add-In out there that accomplishes this (or something similar) already, but I am not aware of one, off-hand.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
