Hmmmm, looks like the second case is something I haven't seen before, I'd recommend logging that with our Subscription Support team or your Reseller.
As for the first item, it looks like a tight connection. I'd try the following:
Option 1:
1. Select the horizontal duct on top, as well as all connecting fittings, diagonal ducts, and the lower horizontal duct.
2. Choose Routing Solutions button on the Options bar.
3. One of the Solutions will be a vertical connection.
Option 2: (A bit more painful)
1. Extend the top duct above the lower duct, don't connect it.
2. From the end of the top duct, choose to create a new run, enter an offset that is below the current elevation, but NOT at the height of the lower duct. You might have to try this a couple times to put in a large enough offset delta for an elbow to fit in.
3. Switch to a 3D view. Delete the vertical section of duct you just created, but not the elbow.
4. Select the Elbow, choose the Connect Into button on the Options bar (this is a new button in Revit MEP 2008). Select the Duct below.
The connection type will depend on the Duct System Family used in the lower duct run (the duct being connected TO).
I hope those solve your problem, otherwise, I'd need a copy of that dataset to solve this routing situation.
Cheers,
Kyle B
Revit MEP Product Manager
Message was edited by: Kyle B [Autodesk]
Kyle Bernhardt
Director
Building Design Strategy
