Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Associate Pipe Sytem to Pipe Type
2 REPLIES 2
EddieFromDC
304 Views, 2 Replies
Is there a shortcut/trick/step that anybody knows that will associate a Pipe System Name to a Pipe Type or vice versa.
When you draw pipe these are the following things to be aware of;
1. System Name
2. Pipe type.
3. Size
4. Offset
5. Workset
Thats a lot of drop down box to select & pick.
Is there a way that when I select the Sytem Type it will change the Pipe Type to the desired one?...One last thing to worry about.
Thanks in advance.
2 REPLIES 2
lanl
in reply to: EddieFromDC
Hi EddieFromDC,
System Type is an instance parameter in the pipe properties, and System Type mainly defines some mechanical properties, and Rise/Drop symbol, it is not relevant to a specific pipe type.
So when select a different System Type, it will not change the Pipe Type.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
EddieFromDC
Thanks lanl....I just had to make sure..
