Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Assign different material in element
2 REPLIES 2
875 Views, 2 Replies
Hello everyone.
I would like to ask some question about assign different material and separate different conduit. I have a problem I need assign different material to same element.
For example I create three type of conduit
1)   telecom conduit, Blue colour PVC,
2)    Signal A conduit, Green colour PVC,
3)    High voltage conduit, Red colour PVC,
If I change the material in manage>object style >conduit >material
than all conduit will be change in same colour.
How can I change separate colour in same type of conduit?
Matthew
2 REPLIES 2
CoreyDaun
I would recommend using View Filters to designate specific colors to your different Conduit Types. You will need one for each separate color with the Filter Rules set to filter by Type Name. These View Filters will then be added to the proper Views (via Visibility/Graphics or View Template) under "Filters". Assign the desired Surface Pattern color override to each View Filter.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Hi Corey,
Thank you for your suggestion .I will try it.
