Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Architectural lighting vs MEP lighting
2 REPLIES 2
769 Views, 2 Replies
How can I turn off the Architectural lighting on a sheet without the MEP lighting turning off. I used the architects lighting for placement purpuses but now everything is dooubled up and looks messy. I do not want to delete them, just turn them off. Any suggestions?
2 REPLIES 2
ASCunningham
You need to go through your Revit Links tab under VG in the view you have or want to pull onto a sheet. This wil allow you to turn off the lights in the arch model but leave your lights on for the sheets you want.
in reply to: ASCunningham
Thanks! This has been driving me nuts!!
