How can I turn off the Architectural lighting on a sheet without the MEP lighting turning off. I used the architects lighting for placement purpuses but now everything is dooubled up and looks messy. I do not want to delete them, just turn them off. Any suggestions?
Solved by ASCunningham. Go to Solution.
You need to go through your Revit Links tab under VG in the view you have or want to pull onto a sheet. This wil allow you to turn off the lights in the arch model but leave your lights on for the sheets you want.
