Ive linked in an Architects model to my MEP model, created spaces (based on their rooms) and for some reason the room name & number is showing as 'unoccupied'. I've checked the Architects model and the room name and number fileds are filled in. Room bounding is also selected in the MEP model.
Any ideas why this is showing as 'unoccupied'?
Solved by WheelerCJ. Go to Solution.
If the architect has a floor finish modeled as a separate Floor element, and Room Bounding is enabled for that Floor, then your Spaces may not read the Room data from the Linked Model. Open up the Linked Model and see if this is the case.
Hi, thanks for your reply.
The problem was because the spaces in the Arch model were created on different phases (existing/proposed/new construction), Once I updated my template to show the same construction phase the 'unoccupied' rooms were filled with the correct room names and numbers.
Hi Corey,
I am having the same issue with MEP Spaces not detecting Room Name and Room Number - and the architects HAVE modelled floor finishes as separate floors (as you describe), and the phases are all the same.
So how do I fix the problem? What do the architects need to do so that the floor finishes are in their model, and I can see my spaces?
Do the architects need to create a whole new model just for floor finishes?
Scott
Found the solution - Floor finishes were checked with "Room Bounding" option.
Un-tick this.
Rooms got confused....
i have a same problem but i did'nt understood the answer can you tell me what u have did by point wise
You start with selecting linked models and using the Phase Mapping under the Edit Type button to match your project phases up to the linked model phases (if different).
Then you pick appropriate phasing and phase filter in the view properties you're working in.
@janio2011 @robert2JCCH Old thread but perhaps some new findings - I'm having the same issues and they seem to relate to Design Options in the linked architecture. The 3x screen grabs shows a Space that is 'finding' its room that is in the Main Model (non-optioned) Room when there is actually another room in a Primary Option in the same location. What I'm finding is that where there is only a Room on this Primary Option (i.e. no room in the Main Model in this location) we get the 'Unoccupied' error. Is this the same behaviour others are seeing?
What you're experiencing is consistent with what others will run into, see (old) topic above.
AFAIK there has been no Autodesk progress on propagating MEP spaces into design options, perhaps someone else can chime in on that front.
Personally, if room programming can change significantly enough that the architect is carrying different design options for room layouts, I would keep that entire area an analytical space until given more concrete data to work with.
Wow, nice to see that OP is only 14 years old - still without a solution? As a work-around you can obviously revert to a scripted/Dynamo solution. I knocked one up that does a simple comparison i.e. is my 'Unoccupied' Space location point inside a Room that has the same area (within tolerance) and level properties and if so, grab the Name+Number properties. This approach seems to fix the clean Design Options problem but unfortunately not all in my case where my Architect has a Room in the same location in both the Main Model and Design Option (Design Option conflict?)
Hello guys,
I had the same issue and the only thing that worked for me was just to turn the "Room Bounding" of the actual Rooms model on! ...yes, in my project we have a dedicated model containing only the rooms
Of course you first need to turn the "Room Bounding" on for all the architectural and structural models that define the boundaries of the rooms. But no need to check the "Room Bounding" on for the MEP models. The MEP are irrelevant in this case
I hope this will help someone!
Hey all, found a good solution for this. If you select the levels in your model you can change the "Computation Height" to above the floor finishes. This will fix your spaces that are being blocked by the floor finishes. This took me many years to figure out lol
