Revit MEP Forum
Archicad to Revit IFC failures
2 REPLIES 2
kadmonkee8
709 Views, 2 Replies
We are working with RME 2012 using a model generated from an IFC file by Archicad
they can not generate ceilings so in place they create Roof Slabs.
This does not help when the ceilings (Roof Slabs) are sloped and we need to place Light fixtures on the slopped ceiling.
Is there a more efficient way to place light fixtures on a sloped surface without using reference planes?
also can you transfer reference planes from 1 project to another?
2 REPLIES 2
CoreyDaun
in reply to: kadmonkee8
kadmonkee8 wrote:
"We are working with RME 2012 using a model generated from an IFC file by Archicad
Is there a more efficient way to place light fixtures on a sloped surface without using reference planes?"
Are your Light Fixtures Face-Based? If so, are they not recognizing the sloped face as a host? You should be able to place your fixtures on any face - but I'm not certain as I have little experience with IFC files.
kadmonkee8 wrote:
"also can you transfer reference planes from 1 project to another?"
With both Projects open, you can Copy/Paste Reference Planes from one to the other. But since you cannot use 'Select All Instances' with Reference Planes, you may have to create a specific View in order to grab all of the ones you want.
kadmonkee8
in reply to: CoreyDaun
Thank you that answered my questions.
i was able to assign the light fixtures to the sloped reference plane in my model.
I did not try to place them on the linked files surface.
i will create all my reference planes and copy them as needed
thanks again.
