Hi Everybody ,, Good day to u ..
I am facing the problem that Revit Archi link model is inserted to Revit MEP in same version 2011 . After linking the Archi Model I only can see grid line and the whole model disappears . I already set up the view range . nothing happen . Please help me to solve the problem .
Cheer
Smile
Thank You Sir for your reply .. I am able to see Archi Linked Model both 3D view & Elevation View but only unable to see in Plan View . I will try to solve my problem according your advice .
Hi Corey
Careful with the guidance on deleting all levels in the MEP
If you have a template which has multiple views set up to help get started with their models which also have specific naming conventions applied then you will lose these and many additions to the database.
Another way to deal with it would be for the user to create an elevation view which is un-cropped and then move the levels to math the Architect's Level 0 and Level 1. Once these have been moved you can monitor these against the Architect's link and then Copy monitor the rest.
Neither way is right or wrong - just depends on how the company has set up the templates, etc.
Know what you mean - just one of many things our co-workers forget to do which means we have to spend ages repairing the models!
