The resolution differences between a monitor and a television are quite different. Using a large TV at a close distance may not be effective and can cause strain. Sit a foot and a half away from your TV for a while and consider what you see. I wouldn't recommend it.
It's not about motion. The window size of the program is not relevant as well. It's about the difference in pixel per inch on a monitor vs. a television. The pixel size in a televisions can be much larger which will make the image more blurry at a close distance. The price is refelctive of the pixel density. Some may be able to tolerate it, other's may not. Just know there will be a difference. Make note of the resolution when considering a purchase. HD tv's get not better than 1920x1080 no matter the screen size. So as the size get's bigger the pixels get bigger.
We actually tried it wondering the same thing. We set up a test station with a large television as a monitor (don't recall the exact size it was something in the 32" to 36" range). We sat several of our users in front of it to do Revit and Ofice products. I don't recall even one liking it. Not as their main monitor at least.
http://en.wikipedia.org/wiki/Display_resolution
Just make sure the TV is 1080P and it has a high contract ratio. like 5,000,000:1 at the least. I used a 32" TV and it worked nicely. example: http://applyazon.blogspot.com/2013/05/vizio-m321i-a2-m-series-razor-led-32.html
My sugestion is NO TV, for exact reasons as mentioned before...DPI.
Look at the HP LP3065.
I use TV and Monitor, I recommend Monitor, I still use TV to be side of the Monitor to review the documents, PDF and specification not for Revit
I have a 27" Dell monitor that I use mostly for email, navisworks, file explorer. Next to that I have a 39ish" 4k Samsung LED TV. That's what I use to work on my Revit models. I love being able to tile the windows for plan, section, 3D, etc and I just appreciate being able to see the extra area around where I'm working. I'll sometimes split the window with Revit and AutoCAD too. I just like having the extra screen area.
It's definitely personal preference though. My boss sits right next to me and he tried it out, and he didn't like it. He goes with 3 Dell monitors for his set up instead.
We use 50" TVs in smaller conference rooms, sometimes to view models internally, sometimes to share screens with remote consultants, and I've worked with firms that use them as their desktops once or twice. I personally would probably hate having it on my desk, but it's useful for conference rooms.
Hi.
If going bigger is your goal, I don't think you can get better than a HDTV.
Look for a Samsung HD screen with HDMI. Not too big though. I used a Mecer monitor and the pixels was awful! Just remember to keep the screen at the correct distance from you according to the size. Using a Samsung as a screen is awesome!
