Revit MEP
norcaljess
Message 1 of 10 (551 Views)
Annotation Symbol in Electrical Family
551 Views, 9 Replies
02-11-2013 07:27 AM
I'm attaching my electrical switch family that I have created.  The reason why I have nested the plate & fixture box families separate is because we need each instance to show up in a schedule.  My problem is that I can't get the $ switch symbol to show up on my plan when I insert the family.  I've tried looking at other switch families where the $ symbol shows up but I must be missing a step.  Anyone know what that is?
Jess
No need to recreate, that should be OK. Open your Family and go to Family Category and Parameters. Check the option "Maintain Annotation Orientation" - that should fix it.
CADastrophe
Message 2 of 10 (545 Views)
Re: Annotation Symbol in Electrical Family
02-11-2013 07:42 AM in reply to: norcaljess
What template did you start with when you created this Family?
norcaljess
Message 3 of 10 (543 Views)
02-11-2013 07:45 AM in reply to: CADastrophe
:smileyfrustrated: I started with an Electrical Fixture template, the reason being, I have almost an identical family for Recepts that I created first, then used that to create this one.  Should I start over with another template?
Jess
norcaljess
Message 4 of 10 (539 Views)
02-11-2013 07:48 AM in reply to: norcaljess
And as far as the template I used to create the Recept family, I started with a 'Generic Model face based' because I want the Recept & Switch families to cut holes in the walls that host them.
CADastrophe
Message 5 of 10 (535 Views)
02-11-2013 07:53 AM in reply to: norcaljess
norcaljess
Message 6 of 10 (533 Views)
02-11-2013 07:56 AM in reply to: CADastrophe
:smileymad:  AAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!
Thank you Corey!!!!
CADastrophe
Message 7 of 10 (528 Views)
02-11-2013 08:02 AM in reply to: norcaljess
norcaljess wrote:
":smileymad:  AAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!"
Breathe...just breathe.  At least it was a simple answer this time, in lieu of the traditional 15-paragraph explanation/work-around!
norcaljess
Message 8 of 10 (504 Views)
02-11-2013 12:34 PM in reply to: CADastrophe
That's what makes me so mad!  I am overthinking things because that's what I normally have to do with Revit, and it was a stinking check box!  And one that I had considered checking to see if it would fix my problem!  BUT I decided it just couldn't be that simple and let it go.  Revit... teaching me a lesson again!
CADastrophe
Message 9 of 10 (501 Views)
02-11-2013 12:48 PM in reply to: norcaljess
Well, if it makes you feel any better, I really didn't think that would work, either...
Oh, well. All you can do is laugh - 'cause if we're not laughing, we're crying. Or throwing our computer across them room...
norcaljess
Message 10 of 10 (498 Views)
02-11-2013 12:55 PM in reply to: CADastrophe
Or... if you are one of the guys I work with... hurling verbal insults at Revit, as if it can understand you or has some personal vendetta against you.  :smileywink:
