Revit MEP
Revit MEP
dtiemeyer
Message 1 of 3 (594 Views)
Annotation Symbol Filled Region plots gray, not black
594 Views, 2 Replies
01-07-2013 12:21 PM
Ive created a Duct Accessory (damper) containing an annotation symbol. In my project, this annotation symbols displays green (based on the fact my Duct System, supply air, is green). However when I print the edge line of the annotation symbol prints black, but the center prints green/gray (color/bw). Even changing the solid fill to 'color black' in the annotation family does not fix this problem.
attached project is rmpe 2012.
Thanks!
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
We've encountered this issue as well - it seems that a solid hatch pattern will plot as its color regardless of the print setup. As a result, some of our "solid" hatch patterns are a series of actual lines, as per the image below.
CADastrophe
Message 2 of 3 (587 Views)
Re: Annotation Symbol Filled Region plots gray, not black
01-07-2013 12:37 PM in reply to: dtiemeyer
dtiemeyer
Message 3 of 3 (577 Views)
01-07-2013 12:58 PM in reply to: CADastrophe
Thanks CADastrophe,
That's the route I've taken as well. I'm going to leave this open to see if anybody else, or perhaps Autodesk, cares to chime in. Cheer.
Dustin
