Revit MEP Forum
Annotation in view not showing up on sheets
2 REPLIES 2
3087 Views, 2 Replies
I'm having an issue where I have sensors and a sensore line (a symbol and a detail line) on my plans but when I create a viewport of the plan on the sheet, the annotation doesn't appear. I've checked the V/G settings and everything appears to be on and the annotation is visible if I go to the plan view. Has anybody solved this before?
2 REPLIES 2
CoreyDaun
The attached View should look exactly the same on the Sheet as is does in the View. Here, it's happened before where someone simply attached the wrong View. Go to your Project Browser, and scroll down to the Sheet View. Click on Expand (the plus symbol) next to it to reveal the list of attached Views. Open that View from here to ensure that it is indeed the correct View.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Yup. That's it. Thank you.
