Is there a way to control the line weight of air terminals that are connected to a system? They take on the line weight of the system (i.e., supply air) and the line weight is too heavy.
Thanks.
Solved by CoreyDaun. Go to Solution.
Do your Duct have differing line weights between Systems? If not, then you can remove the line weight override from the Systems under each System's Type Properties. If they do differ, a View Filter (for the Air Terminals Category and blank rules) will override the System Graphics Overrides; note that the View Filter will also override the Phase Graphics Overrides, so any lighter-toned existing Air Terminals will inherit the set line weight.
