I system that contains a fan connected to 3 return diffusers. The airflow should be 1500, but according the the fan's airflow, its 0. Why isn't the actual airflow reflected in the fan?
The equipment connector properties should be:
Flow configuration - CALCULATED
Flow Direction - IN
System Type - RETURN AIR
Loss Method - NOT DEFINED
The terminal connector properties should be:
Flow configuration - PRESET
Flow Direction - OUT
Loss Method - SPECIFIC LOSS
Also make sure the flow parameter is defined with the default flow parameter
Did you create a system?
