Revit MEP
Hugh_Compton
Message 1 of 2 (188 Views)
ABS Reducing Bushes - Restrict Sizes To Lookup Table
188 Views, 1 Replies
01-17-2013 01:31 AM
Hello
I am trying to set a template fille up so that ABS fittings sizes are restricted to the sizes on a lookup table.  On the template I have transitioned from 100mm down to 65mm.  Revit has 'invented' a custom bush that isn't in the sizes I have entered in the lookup table.  Is there a way to force Revit to only use fitting sizes from the lookup table?
i.e. this would normally be something like 2 bushes in total to transition between the 100mm (4") to the 65mm (2 1/2") since my supplier doesn't make 100mm to 65mm bushes.  The Lookup table used in the bush family is pointing correctly to my custom lookup table.
Hugh_Compton
Message 2 of 2 (149 Views)
Re: ABS Reducing Bushes - Restrict Sizes To Lookup Table
01-18-2013 07:58 AM in reply to: Hugh_Compton
Not sure about the restriction that I wanted BUT I have found a workaround - using the link below(showing use of IsCustom family parameter) I have made any 'custom' fittings that aren't found in the Lookup csv file appear RED.  This is very useful to me.
http://www.andekan.com/blog/2011/11/25/family-feedback-mechanisms-part-2/
