Hi all.
I read the Guide Revit.
But not catch when running Duct,When the angle of affects.
Can they function as the picture show??
Solved by L.Maas. Go to Solution.
I am not sure if I understand you correctly. But the function works.
In the screenshot I used the three selections to draw ducts.
In the second option you will see that if I draw a duct at an angle, at a certain point it will place an angle of 45° or if angle is too small it keeps straight
Something similar happens in the third option. It remains straight or chooses an angle which is closest within the list.
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you very good tips
