Revit MEP Forum
2014 fitting angle
1 REPLY 1
revitworkbench
283 Views, 1 Reply
2014 fitting angle
Does anyone know if it is still possible to schedule fitting angles in revit 2014? I dont see it in my available fields anymore. thanks
1 REPLY 1
CoreyDaun
in reply to: revitworkbench
The Angle parameter wasn't directly available before, either. There is a work-around method that involves creating a Shared Parameter (Angle), adding it to every applicable fitting family as an Instance Parameter, and setting the formula to "= angle" (or whatever the name of the controlling angle parameter). This Shared Parameter could then be Scheduled and Tagged to retrieve the fitting's Angle.
