Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
2013 Section view graphic display changes depending on angle
4 REPLIES 4
Jrobker
441 Views, 4 Replies
When I rotate a section, the section view toggles between wireframe and shaded, but the view is set to shaded.
I have toggled the hardware acceleration, tested another users machine, update 2 installed.
This only happens on 1 project.
Ideas?
Video seen here
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
4 REPLIES 4
CoreyDaun
in reply to: Jrobker
Strange. Does it behave the same if you draw a new Section horizontally, set it to Wireframe, and then rotate the new one?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
āž|āž Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Jrobker
in reply to: CoreyDaun
Yes it does. I'm cluless on this one.
We also had 1 plan view duct shaded, but all of the fittings wouldn't.
We had to delete the view and re-create a new one.
CoreyDaun
Maybe it has something to do with the round duct. Tee a rectangular duct into the main and then rotate that Section to view it...
Jrobker
[Solved]
It turns out it has to do with the linked civil site DWG file.
In the DWG file there was an entity miles away on the site plan.
We deleted the element and reloaded the DWG into RVT and the sections work as expected now.
