Okay, I have seen how to insert the Lookup Table inside of the fitting in 2015. That is not the issue. The issue comes in when I change the Diameter of the fittings. Please see below. I will place a 2012 with all ends at 3" works fine I take the exact same file with the lookup table inserted and try to change the ends to 3" it gives me the error below. They both use the exact same Lookup Table. I am assuming I will have to recreate this fitting in 2015? I have a lot of them to do if so.......
Purus you are right
In the family NH-22 Lookup Table is missing.. find the lookup table, import to manage tookup tables... will be OK
