2008 NEC 210.4 (B) (and later I think) require multiwire branch circuits (circuits that share a neutral) to be fed from multiple pole circuit breakers. So a 3 circuit homerun feeding receptacles with a shared neutral require a 3 pole breaker at the panel. How is this accomplished in Revit? Workaround: dedicated neutrals. Thanks.
At least 35 states have adopted the 2008 NEC. C'mon Sparkies! What are you doing in Revit to comply with this rule?
