Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
(2) Network Licenses used for Revit & AutoCAD on same machine
5 REPLIES 5
MagicJS
411 Views, 5 Replies
Why are two network licensed being used when a single workstation has Revit and AutoCAD open?
Each workstation is supposed to be only be using a single license not each program open on the workstation.
Is this happening to anyone else? Does the network license manager need special configuration?
Users of 65200REVSYP_F:  (Total of 12 licenses issued;  Total of 12 licenses in use)
  "65200REVSYP_F" v1.000, vendor: adskflex
  floating license
    jsun jfkm101 jfkm101 (v1.000) (jfkmcgfs2/27000 3040), start Fri 2/24 16:29
    jsun jfkm101 jfkm101 (v1.000) (jfkmcgfs2/27000 325), start Fri 2/24 16:20
5 REPLIES 5
DarrenP
in reply to: MagicJS
can you attach the log file?
what version is this?
DarrenP
MagicJS
in reply to: DarrenP
Rest of the license manager status log.
Status
Flexible License Manager status on Fri 2/24/2012 16:30
[Detecting lmgrd processes...]
License server status: 27000@jfkmcgfs2
License file(s) on jfkmcgfs2: C:\Program Files\Autodesk Network License Manager\license\combined 2009-2010-2011-2012 licenses.lic:
jfkmcgfs2: license server UP (MASTER) v11.5
Vendor daemon status (on jfkmcgfs2):
adskflex: UP v11.5
Feature usage info:
floating license
MagicJS
Running 2012 on both.
DarrenP
i noticed your running an older version of Flex LM try updating it to 11.9
DarrenP
TravisNave
Agreed.  If you want to avoid undesired license behavior, always make sure you are running the latest version of the NLM for your products.
http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Network-License-Manager-2012/m-p/29627...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
