Revit MEP Wishes (Read Only)
dtiemeyer
1470 Views, 1 Reply
Worksets
I would like to see the worksets put in a more Obvious location. Or better yet, let us assign a default workset to a view, kind of like the r2013 'Linked View Template' setting - you could change it to none if you needed to draw on a different workset.
I guess the same thing could be done with Design Options.
At least consider moving them from the bottom to somewhere at the top, like the Options Bar, or possibly a new dialog box component that could sit atop properties or allowed to float. People just forget to look at the bottom of the screen when they draw.
My other CAD is a Cadillac and I like to Revit to the Max!
1 REPLY 1
dtiemeyer
in reply to: dtiemeyer
Furthermore, if a user has dual displays and stretches Revit across both screens, those pulldown/up menus end up on the right hand screen, which is typically not the 'primary' display as most users leave Properties & Project Browser on the far left.
