Revit MEP Wishes (Read Only)
Showing results forĀ
Did you mean:Ā
Revit to check for reload latest BEFORE going into the changes
1 REPLY 1
lfazio
979 Views, 1 Reply
While mangaing worksets in a link, can a check for reload latest be done before I go through all the changes.
1 REPLY 1
lfazio
in reply to: lfazio
I want to add to this one.  Please have it check for reloading latest before creating revision clouds.  I just spent all the time to draw the revision cloud only to find that when I was finished and went to close the command that it tells me it can't and to reloaded latest, which means cancel the command  and thus losing all of the work.  Once again, one step forward, three backward.
