Revit MEP Wishes
Revit MEP Wishes
apaupert
Message 1 of 4 (303 Views)
Non-Selectable Links Setting
303 Views, 3 Replies
02-20-2012 04:21 AM
I would like a right click feature when hovering over a link to make the link non-selectable. Just like how AutoCAD works with Excel files linked in. Filtering/pinning the links are good but non-selectable would be great!
CADastrophe
Message 2 of 4 (294 Views)
Re: Non-Selectable Links Setting
02-20-2012 08:04 AM in reply to: apaupert
I absolutely agree with this, as well as most users would, I imagine.
Discussed in this post is a work-around method of achieving this. However, this is NOT a solution, nor is it flawless.
New Member
mmorga84
Message 3 of 4 (252 Views)
09-18-2012 01:02 PM in reply to: apaupert
Bump!
Can't believe this is still not implemented.
Every person I've ever talked to working in MEP notes this as a significant annoyance.  After I set up arch/structural linked models and pin them, I NEVER want to select them again.
Mis-clicks and the resulting 5-10 seconds of lost time happens every couple of minutes.  That is a big loss of efficiency.  Seems like a very easy fix to just add the unselectable option.
thombrady
Message 4 of 4 (226 Views)
10-04-2012 01:37 PM in reply to: apaupert
Everyone who uses REVIT, will ever want to use REVIT & those who are not even born yet want this feature. I cannot beleive how many times I cannot even select a duct or put a diffuser in because for some reason the link is preventing this! Please, Please implement this. Make it unselectable, if I want to select it I will open up the Link itself & do what I have to do then reload it back in.
