Revit MEP Wishes (Read Only)
Non-Selectable Links Setting
3 REPLIES 3
apaupert
666 Views, 3 Replies
I would like a right click feature when hovering over a link to make the link non-selectable. Just like how AutoCAD works with Excel files linked in. Filtering/pinning the links are good but non-selectable would be great!
3 REPLIES 3
CoreyDaun
in reply to: apaupert
I absolutely agree with this, as well as most users would, I imagine.
Discussed in this post is a work-around method of achieving this. However, this is NOT a solution, nor is it flawless.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
mmorga84
Bump!
Can't believe this is still not implemented.
Every person I've ever talked to working in MEP notes this as a significant annoyance.  After I set up arch/structural linked models and pin them, I NEVER want to select them again.
Mis-clicks and the resulting 5-10 seconds of lost time happens every couple of minutes.  That is a big loss of efficiency.  Seems like a very easy fix to just add the unselectable option.
Everyone who uses REVIT, will ever want to use REVIT & those who are not even born yet want this feature. I cannot beleive how many times I cannot even select a duct or put a diffuser in because for some reason the link is preventing this! Please, Please implement this. Make it unselectable, if I want to select it I will open up the Link itself & do what I have to do then reload it back in.
