Revit MEP Wishes
3 Kudos
Post 1 of 4
Master-Slave Ltg
63 Views, 3 Replies
08-08-2007 08:09 PM
Wish list:
1. Using master-slave troffer lighting fixtures is very common especially in CA. For example when you show two 3 lamp light fixtures, the branch circuit connects only to the master fixture, which contains a 4 lamp ballast and a two lamp ballast. Then the slave fixture connects to the master fixture.
Distinguished Contributor
6 Kudos
Post 2 of 4
Re: Master-Slave Ltg
09-13-2007 01:40 PM in reply to: sparkie001
Yes where is the ability to do multi-level switching. I do many schools and some of the compact fluorescent highbay can have up to 4 seperate switching poles. How do I address this?
6 Kudos
Post 3 of 4
10-25-2007 03:24 PM in reply to: sparkie001
We use a lot of multi level switching as well. I recently used a fixture that could possibly have up to 4 different switch legs.
0 Kudos
Post 4 of 4
01-06-2010 11:57 AM in reply to: sparkie001
Does anyone have an answer for this?
Post to the Community
New Post
