Revit MEP Wishes (Read Only)
Master-Slave Ltg
3 REPLIES 3
sparkie001
278 Views, 3 Replies
Master-Slave Ltg
Wish list:
1. Using master-slave troffer lighting fixtures is very common especially in CA. For example when you show two 3 lamp light fixtures, the branch circuit connects only to the master fixture, which contains a 4 lamp ballast and a two lamp ballast. Then the slave fixture connects to the master fixture.
3 REPLIES 3
Jarom05
in reply to: sparkie001
Yes where is the ability to do multi-level switching. I do many schools and some of the compact fluorescent highbay can have up to 4 seperate switching poles. How do I address this?
Jarom05
We use a lot of multi level switching as well. I recently used a fixture that could possibly have up to 4 different switch legs.
ACOVA
Does anyone have an answer for this?
