I would like to see the following tools to speed up the painful process of revising electrical layouts:
Uncircuit Elements
All selected elements are quickly removed from all Electrical Circuits.
Unswitch Elements
All selected elements are quickly removed from all Switch Systems.
Disconnect Elements
All selected elements are removed from all Electrical Circuits and Switch Systems.
Join Circuits
Select two electrical circuit with compatible properties, and they are combined into a single circuit.
Split Circuits
Select an electrical circuit, and then select one or more elements that belong to that circuit and they are added to a new Electrical Circuit.
Match Connections
A source fixture is selected, and all additionally selected Elements are added to the source's Electrical Circuit and Switch System, if applicable.
Edit Panel Schedule
This should be available while an Electrical Circuit is selected as well, not just a panel.
Create Identical
This would function just like Create Similar, except that it would connect the new Elements to the same systems as the source element.
All of this is very possible with the current tools, but it is extremely cumbersome and slow. These tools would speed up the process.
+100
Yes, please add all these features. Recircuiting is not fun, especially as I found out that Wires DO NOT update when you re-circuit. I have already added that to the wish list.
