Revit MEP Wishes (Read Only)
Current Revision - workflow improvement!
2 REPLIES 2
RaoulTittel
334 Views, 2 Replies
Hi all,
I have a suggestion for a workflow improvement with regards to exporting/issuing drawings files. Would it be possible to have the batch export/print function modified so that the 'current revision' letter/number is added to the end of the drawing file name. e.g. the drawing file that is created from the title sheet A-001/4 is exported as A-001 (4).dwg. Or in the case of printing to PDF it could have the same. This would save me and many others shed-loads of time.
Please can we have this. Or if it exists can someone tell me where to get it.
Cheers,
Raoul
Using Revit 2012
2 REPLIES 2
embolisim
in reply to: RaoulTittel
Hi Raoul,
In the mean time use this;
http://www.bulkrenameutility.co.uk/Main_Intro.php
Its free & has a 64 bit version.
RaoulTittel
in reply to: embolisim
Thanks embolism. What a curious name, I hope you don't have one in the near future. I'll download that program as a stop-gap for now but I'd like something like that built in to Revit.
Cheers,
Raoul
Using Revit 2012
