When a connector is created in a family there is a parameter called Connector Description that can be filled in. It would be helpuf if this discription showed up when you went to connect to the connector. Currently system type, size and elevation are shown. Or maybe I just need to know how to turn on this info. Otherwise the connector description isn't much good.
