Revit MEP Wishes (Read Only)
Conduit Service Type
1 REPLY 1
tkendrick
1259 Views, 1 Reply
Once you apply a name to the Conduit Service Type, that name should continue on from the conduit. If you draw a section of conduit and end it, and continue it on that name should transfer to the new conduit you draw, I currently have to reselect the conduit network and re-type the servic type to apply it the entire run.
Use this link to tell Autodesk about features you need:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
1 REPLY 1
CoreyDaun
in reply to: tkendrick
This simple issue helps to illustrate the poor level of intelligence of the Conduit Systems.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
