Revit MEP Wishes
Revit MEP Wishes
11 Kudos
Post 1 of 16
Autodesk Professional Revit MEP Certification?
2405 Views, 15 Replies
05-11-2012 09:14 AM
It may exist and if it does I'd like to know where I can get this... But I'd like to see Autodesk Professional Revit MEP Certification. Right now it looks like there is certification that is totally focused on Architectural. I never bothered with this Certification because what I do for my company is only MEP and this certification means nothing to me as I NEVER deal with building a wall/floor/ceiling. I want a certification that shows what I know on only the MEP features. I could probably pass the Architectural Certification but why bother?
Valued Contributor
11 Kudos
Post 2 of 16
Re: Autodesk Professional Revit MEP Certification?
05-15-2012 05:02 AM in reply to: apaupert
Same here. Please add Revit MEP Certification.
Use this link to tell Autodesk about features you need:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Active Member
2 Kudos
Post 3 of 16
05-15-2012 11:36 AM in reply to: apaupert
Same here, there are tons of MEP only firms out there.
Jason H. Sousa
HPD, LLC
Phone: 770-455-7707 Ext. 148
E-mail: jsousa@hpdengineers.com
Fax: 770-455-4532
Valued Contributor
11 Kudos
Post 4 of 16
08-24-2012 09:11 AM in reply to: jsousa
Wow! There must be more than THREE of us who use Revit MEP and want a certification for it.
Bump!
Distinguished Mentor
24 Kudos
Post 5 of 16
09-05-2012 10:58 AM in reply to: tkendrick
I'd get certified.  What's there to certify in Architectural, anyway?
Maybe they could use the User Status on these forums.  I see some people with "PRO".  I've been a "Distinguished Mentor" for a while.  Do I get a free Ice Cream?  1/2 price on my next pizza from Pizza Hut?
Valued Contributor
11 Kudos
Post 6 of 16
09-05-2012 11:11 AM in reply to: asommer
That's a good idea.
I took the AutoCAD Certification. It's a practical type exam. Multiple choice, or fill-in answers, and you are presented with an image and description of what you need to do to find the answer. It's a test to see if you can use the basics of the software. Or at least for AutoCAD it was. I imagine the Revit Arch test is similar, you have to manipulate objects so you can produce the answer. Usually the answer was some form of dimension or property of an object.
The tests aren't easy. I took the Professional test twice.
4 Kudos
Post 7 of 16
09-18-2012 09:54 AM in reply to: apaupert
I also work in an MEP only firm and this certification would likely be a good line on my AND my firms resume.
All of my "professional" training came from Revit Arch.but all of the "real world" training was on MEP and I really feel MEP has a lot more depth to it. Maybe Autodesk is just waiting until more users work on Revit MEP, I know the Architectural industry has been in Revit for a good deal longer then MEP firms, then again maybe the Arch test is just more cost effective to produce because there isnt much to it.:smileyvery-happy:
New Member
2 Kudos
Post 8 of 16
10-08-2012 02:18 AM in reply to: apaupert
this is in high demand...Why is this not available for Revit MEP? or maybe i should ask..."WHEN" will this be available?
Member
1 Kudo
Post 9 of 16
01-11-2013 10:20 AM in reply to: apaupert
I also work for a MEP contractor. i've been using Revit MEP for the last 4 years, and having a certification to validate my experience would be great. i know that i could pass the Architectural test too, but don't see any value in that at this point.
Member
2 Kudos
Post 10 of 16
02-08-2013 06:30 AM in reply to: apaupert
Yeah, please add Revit MEP Professional cert :smileyhappy:
