Revit MEP Wishes (Read Only)
Align Sections to Elements at Odd Angles
0 REPLIES 0
Message 1 of 1
923 Views, 0 Replies
Would be nice to use the alignment tool to do the above. Rotating the section marker is not accurate enough to do this when you need to perform duct/pipe routings/connections that can't be done under "generate layout". Seems like this should be easy for you guys to do.
Haven't used 2013 on a project yet. Not sure if this has been added.
Thanks in advance.
0 REPLIES 0
