hello
i used to work on Autocad MEP, and when i draw a pipe, i can inset flow arrow to show on which direction the water goes
i know Autodesk Revit is more advance, but when we plot (in black and while) the whole pipes are looking the same
there should be a small thing to add in the revit to make it like the Autocad MEP
dont you agree, i dont think this will be a hard task to add and am pretty sure that create it wont add "extra" size more than 2 GB for the recvit to install
hope that you would put it in your consideration
regards !!
Variable Integrated Package L.L.C
Abu Dhabi - United Arab Emirates
