I know if you go to the MEP Settings, you can create a new "Fluid Type" and give the Temperature, Viscosity and Density, but the flow characteristics and the fluid behaviors are different with steam and refrigerant.
We definitely need Steam and Outside air Connectors, Systems, and Flow parameters. Autodesk, keep in mind there are multiple different steam systems, too, varying in pressure!
