Revit MEP Wishes
Revit MEP Wishes
Distinguished Mentor
24 Kudos
Post 1 of 10
Add Piping Systems & Connectors
403 Views, 9 Replies
01-13-2010 09:53 AM
We need more piping systems, such as- "Tempered Water" (works like Hot or Cold, using "Other" doesn't work) systems and connectors, and Hot Water Return (loops back into Hot Water) systems and Connectors. Maybe even Soft Water, but I think I can work around that.
24 Kudos
Post 2 of 10
Re: Add Piping Systems & Connectors
01-15-2010 10:33 AM in reply to: asommer
Also, a Water Meter is needed to terminate Piping Systems.
24 Kudos
Post 3 of 10
02-08-2010 10:44 AM in reply to: asommer
I tried a Recirculation system, The Recirculation pipe goes from the "Hot water system" to the "Cold water system", just before the Water heater. This doesn't agree at all with the Revit MEP systems. Even if I loop the return within the hot system, the flows go away completely. This would need to be worked out in order to connect everything up properly.
24 Kudos
Post 4 of 10
02-08-2010 02:18 PM in reply to: asommer
Also-
Gas (natural gas, Propane) connectors, CFH unit
Compressed Air (Oxygen, Nitrogen, Medical Gasses) PSI unit
24 Kudos
Post 5 of 10
02-09-2010 09:23 AM in reply to: asommer
Refrigerant Types (Liquid and Suction-Gas), PSI unit?
Temperature Losses and Vertical lengths critical!
Valued Contributor
0 Kudos
Post 6 of 10
02-10-2010 09:10 AM in reply to: asommer
Steam would be nice too, and a parmeter data type for steam flow (e.g. mass / time) would be really useful, too.
And...on the duct system type list, how about one for Ventilation Air (aka "Outside Air") ?
24 Kudos
Post 7 of 10
02-10-2010 11:50 AM in reply to: asommer
I know if you go to the MEP Settings, you can create a new "Fluid Type" and give the Temperature, Viscosity and Density, but the flow characteristics and the fluid behaviors are different with steam and refrigerant.
We definitely need Steam and Outside air Connectors, Systems, and Flow parameters. Autodesk, keep in mind there are multiple different steam systems, too, varying in pressure!
24 Kudos
Post 8 of 10
02-18-2010 06:35 AM in reply to: asommer
We also need a proper "Welded" Connection for piping, something like a Tap that doesn't break the main.
1 Kudo
Post 9 of 10
03-10-2010 11:32 AM in reply to: asommer
Medical Air system
Medical Vacuum system
Medical Nitrous Oxide system
Medical Nitrogen system
Medical Oxygen system
Medical WAGD system
Carbon Dioxide system
Sanitary Vent system
Hot Water Return system
DI Water system
Storm Drain system
Natural Gas system
plus an absolute shit ton of more parts included for Plumbing/Medical
24 Kudos
Post 10 of 10
03-10-2010 03:18 PM in reply to: asommer
This guy knows how we do. I hear 2011 is coming soon, no comments specifically on content due to beta program confidentiality agreements, but the word is good. we'll see. we all have high hopes, Autodesk!
