Revit MEP Wishes
Revit MEP Wishes
Distinguished Contributor
62 Kudos
Post 11 of 22
Re: Add ceilings to copy/monitor
10-11-2011 10:17 AM in reply to: brenden.haskins
Here's a meme I created related to our troubles:
I think it sums it up quite nicely.
____________________________________________________
Please give kudos to the MEP Wish List ideas you like, as this will help the Revit development team prioritize functionality additions!
1,007 Kudos
Post 12 of 22
10-11-2011 11:21 AM in reply to: thewrz
I guess you have to admire his zeal. I would be afraid, had he a pitchfork to accompany his torch. (Or maybe a Q-Tip if I am mistaken...)
Distinguished Mentor
24 Kudos
Post 13 of 22
10-13-2011 08:32 AM in reply to: thewrz
He's Pointing at the Architect's ceilings.  Tell'em!
We need the ceilings to Copy/Monitor too.
1,007 Kudos
Post 14 of 22
01-20-2012 07:36 AM in reply to: thewrz
Our architectural friends have come to the realization that they must lower their ceilings in a couple of major rooms to accommodate the existence of our obtrusive equipment. It is easy enough to change these few rooms, but while investigating, I found that they had changed many other ceilings (mostly heights, but a couple types as well). Now we have a coordination issue or two, but I don't know if that would have been caught had they not changed the major ceilings. I'd like to think it would've been, but if the ceilings were Copy/Monitored...
62 Kudos
Post 15 of 22
02-24-2012 11:17 AM in reply to: CADastrophe
...I see what you did there. Let's bump this thread some more. Get it to the top again.
Valued Contributor
1 Kudo
Post 16 of 22
06-14-2012 04:03 AM in reply to: brenden.haskins
Yes this is a big problem with the ceilings.
Also why are lighting families upside down?
1,007 Kudos
Post 17 of 22
06-14-2012 05:47 AM in reply to: brian.breslin
I assume your light fixture families are face-based?
If hosting to a ceiling, they are probably just hosting to the top face of the ceiling, instead of the bottom. This seems to be common with Generic Ceilings. To flip the fixture, click on the 'Flip Work Plane' icon that appears when the element is selected.
If hosting to a Reference Plane, the direction in which the Reference Plane is drawn (L to R, R to L) determines which side the fixtures will be on. You will want to draw it RIGHT to LEFT in order to get fixture to mount on the bottom of the plane.
Valued Contributor
1 Kudo
Post 18 of 22
06-15-2012 03:31 AM in reply to: CADastrophe
thanks,
Good info to know that, we have been using ref. planes for angled ceiling, so will try going right to left next time.
62 Kudos
Post 19 of 22
01-28-2013 01:53 PM in reply to: brian.breslin
Just a humble bump.
We need this. Desperately. It would make our lives so much cleaner us MEP consultants that do the bulk of the lighting design for a project (we pick the luminaires, do the calcs, and visualizations).
Having to create a rendering model and not being coordinated with the Architect is a real pain.
If we could copy-monitor ceilings (and the Architect in turn monitors our copied ceiling against their original one) we could truly coordinate bi-directionally.
So if we host to the copy-monitored ceiling and cut into it, the Architect is prompted the next time they reload their model that the ceiling has been cut (sketch is missing, I believe is the warning), and they can in turn cut their ceiling thus revealing our fixtures.
I can't think of a reason why this hasn't been implemented, when I can copy monitor floors and walls why can I not copy-monitor ceilings?
I would love a real reason why this functionality has remained absent for 3 version cycles. Are the mechanics involved with implementing it exteremly difficult? Is it because ceilings can be sloped? What gives?
It just drives me nuts.
Valued Contributor
1 Kudo
Post 20 of 22
01-31-2013 05:33 AM in reply to: thewrz
Yes, we have had problems with this too, lights become un hosted when we update a linked model from architect and he has moved his ceilings.
Also looking at the 2d plan you cannot tell so our engineers are missing them.
If ceilings were copy monitored this would sort this problem easy.
