I have an MEP File with an architectural file linked in.
All I want to do is transfer the project info so that the titleblocks are the same.
When I go to transfer these, I get an error in my MEP file saying "The conduit has been modified to be in the opposite direction or insufficient space to create the required fittings."
it has (4) errors, each of which it is blowing my conduit routing up... mostly where there are 90 degree bends in the conduit and causing the fittings to look like they are backwards, etc.
Why is this happening? I only want to trasfer the Project Info for titleblock reasons and it is causing my conduit model to have errors and disconnect my conduit?
I have seen this error before with pipe and duct, but have disregarded it before, but this time did notice it was screwing up my drawing.
thoughts?
Have you investigated the locations in which these errors are occurring? You should be able to get the Element ID from the error messages, cancel/undo the 'Transfer Project Standards', and use 'Select by ID' under the Manage tab. Perhaps try recreating those elements.
