Switchboard Phase/Load Balancing
casquatch
Message 1 of 10
casquatch
I've looked around quite a bit and couldn't find any information on this, so any help or direction would be appriciated.
We have a distribution panel that is defined as a switchboard. The panel schedule works as needed EXCEPT we are unable to move any 2-pole circuits to the B/C phases. Is this just a limitation (I'm thinking yes), or is there some fancy way to get the loads to move over?
We tried the Panelboard/1-column schedule idea, but in the end the circuits are listing as 1,2,3 and we would like them listed as they would with a switchboard panel (showing 1 number per circuit, regardless of poles).
Any thoughts? What have others been doing?
We are running in Revit 2015 currently.
Thanks!
Casey
Replies (9)
Message 2 of 10
fabiosato
I have found out that switchboard fits to 3phase loads, 2 phase and 1 phase will use from phase A, so 2 phase (AB) and 1 phase (A).
You can try to make loads 3 phase unbalanced and place values to phases B and C. I didn´t tried it.
Fábio Sato
Message 3 of 10
Sorry to comment on an old thread, but this is a problem that still exists on Revit 2017.
See my screenshot for an example.
Has anyone here found a fix?  I think fabiosato's workaround should work, but it's a painful workaround to use on numerous circuits.
Ryan
Message 4 of 10
Disconnect your 2-pole loads from the SB, place a 1 pole spare in the schedule, and reconnect the loads.
Message 5 of 10
Fabiosato's idea sorta worked. Smiley Indifferent
BSammis' idea didn't. Smiley Sad
Message 6 of 10
It works if you change your DB family part type from "switchboard" to "panelboard" and use a modified single column panel schedule.  Which is also how we get around the disconnect between lines in the schedule and total number of 1 pole breaker spaces in the panel.
Message 7 of 10
bsammis,
Thanks.  That works pretty well, and I'm satisfied enough to use this method going forward.  However, I don't love the numbering.  As casquatch said in the OP, we want the circuit numbers to be 1 digit, like a switchboard.  Do you have a fix for that?
Message 8 of 10
scbunker
Anybody have an answer for this?
Message 9 of 10
scbunker
I've created an Idea for this. It is important that we have this functionality in the software.
https://forums.autodesk.com/t5/revit-ideas/allow-selection-of-phases-in-switchboards/idi-p/7381023
Please go vote for it and maybe we'll see it happen!
Message 10 of 10
Martin__Schmid
A solution to this was implemented in Revit 2021.  See this help topic.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
